is there a filtering element there somewhere?
something that should be cleaned/maintained?
there's a filter inside the fuel pump.
should be detailed in the service manual.
i think it's a 15K mile replacement item - but don't remember off hand.
if you have things taken apart to this point - it's probably a good time to deal with it.
how do you get the stock fuel gauge off the tank? Does it just pull off?
It pulls straight out.. don't twist it as you'll mar the plastic lense. Also on an '06 Street Bob, the wires go through a tube & come out under the tank to a connector. The pins have to be removed from the connector before you can pull the wires out through the tube as the connector is larger than the tube diameter. I just cut the wires an inch or so from the connector & resoldered & shrink tubed it back together.
