Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 03-04-2006, 12:27 AM
PowerCobra98's Avatar
PowerCobra98 PowerCobra98 is offline
Default ECM Calibration Numbers and Reason Why 06 Stage 1's Are Lean
Well friends, I got to digging around the web today and I ran across some interesting information. I found some charts that list the part numbers for the stock and performance ECM calibrations. For the "performance" calibrations it lists the "required configuration" for your bike to have in order to get a certain calibration.
For the 06 Dyna Stage 1, you'll notice that in the Required Configuration column that it basically only covers having a SE Air Cleaner. It also calls for stock exhaust!! Which means that if you have the SE Air Cleaner and aftermarket exhaust pipes (SE Pro II in my case) then you will almost without doubt be lean because your exhaust will be flowing more freely than the stock setup. If you look down the chart further it gets really remarkable. You'll notice that the calibrations call for stock exhaust until you get to the level of "1550 Stage 2 Race"!! This seems shocking to me because the first thing almost everyone changes is the exhaust pipes.
I personally don't believe it means that if you have the SE Air Cleaner and aftermarket exhaust that you are going to harm your engine if you have the Stage 1 calibration because it's a little lean. If you beat on the bike and do full throttle pulls up to redline then yes it would probably not be a good idea but for all other general riding I would think you'd be just fine. At any rate the charts are posted below for you to draw your own conclusions.
[IMG]local://upfiles/5333/D851E2C1CBAD40C4B202A88426F8A570.jpg[/IMG]
[IMG]local://upfiles/5333/0250ABD86D8D4C5FABD12B2DBFF478D4.jpg[/IMG]
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
- Scott - <><
2006 Dyna Super Glide Custom - FXDCI
!@#$&^*% where's the freakin' horn on this thing??
Old 03-04-2006, 03:10 AM
Whiffleboy's Avatar
Whiffleboy Whiffleboy is offline
Default RE: ECM Calibration Numbers and Reason Why 06 Stage 1's Are Lean
Yikes! I see a TFI in my immediate future.
Whiff
__________________
Old 03-04-2006, 03:21 AM
tarathatcher tarathatcher is offline
Prospect
Excellent info! And definitely interesting...
Old 03-05-2006, 04:02 AM
billybobber billybobber is offline
Hang Around
FYI-
Those are apperently somewhat old charts. The sert i just bought manufactured in Feb has new map configurations available for the SEII slip ons as well as the new 25 deg Injectors for the 06 dynas.
Glad i waited to get mine. I had no idea of how often HD revises these CD's
Old 03-05-2006, 04:08 AM
KBFXDLI's Avatar
KBFXDLI KBFXDLI is offline
Quote:
ORIGINAL: billybobber
FYI-
That's EXACTLY why I'm getting the newer model SERT. My dealer said the new release might have a pre-set Map for my configuration and I won't have to dyno the bike which will save me $300.
__________________
06 FXDLI
Many thanks to our people in uniform for it is their courage and sacrifice that makes our nation great.
Old 03-05-2006, 11:16 AM
FYI-
The date on those charts is December 05. If they've revised maps since then that is great. I was just passing on information I found.
Please answer these questions:
1. Where did you get your SERT from?
2. How do you know it was manufactured in February?
3. How do you know the manufacture date of the SERT you're buying before you buy it?
4. Can you ABSOLUTELY verify that your SERT has a preconfigured map for a Stage 1 2006 Dyna with SE Air Cleaner, SEII Pro Slip-Ons, and 25 degree injectors?
__________________
- Scott - <><
Old 03-06-2006, 12:49 AM
Hang Around
98,
1) Zannoti.com (365 bucks)
2) look at the part # sticker on the box. It will have a born on date there as well
3)See #2 and look before buying if going to a dealer. On the net it's impossible to know really. Typically the ones bought at dealerships may have been in stock for a while sitting on the shelf getting old meaning you might not get the latest version. Ordering online usually brings in the latest version due to the high sales volume due to cheaper prices.
4) I absolutely guarantee my version (4.5.3) has the map you desire with the SE AC, SEII slip ons ans 25deg injectors!!!! You can tell what version you have by looking at the # below the SE icon once you load it on your desk top.
I will attempt to post the pdf cal list in my next post following this
Old 03-06-2006, 01:04 AM
Hang Around
Calibration # 59: 2006 Shotgun / Shorty Dual Exhaust with O2 Sensors
Configuration: 1450 SE A/C & Mufflers
File Name: 141NX104-A0.MT6
Components:
• 25deg Injectors P/N 27709-06
• SE Air Cleaner and Breather Kit P/N 29440-99C
• SE II Slip-Fit Mufflers P/N 80448-03 or 80258-99A
Here is the text from the PDF file
98,
Thanks for answering those questions!
Couple more for you if you don't mind...
1. What's your SERT part number? Is it 32107-01E?
2. What's your CD part number? Is it 32117-01G?
I have a feeling I already know what they are from reading some other posts but I want to make sure I get the correct items the first time so I can load and go. Once you confirm your numbers I should know what I need to get.
__________________
- Scott - <><
Old 03-06-2006, 01:06 AM
Components:
Oh, hell yeah!! That's EXACTLY what I need! Thanks!
__________________
- Scott - <><
Tags
06, 2009, 25deg, 2770906, 3211701g, calibration, calibrations, dyna, dyno, ecm, harley, hd, injectors, pn, stage
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
