Harley Bullet Headlight replacement
Old 06-08-2008, 06:17 PM
Airborne350G's Avatar
Airborne350G
Airborne350G is offline
Default Harley Bullet Headlight replacement
Does anyone know how to replace the bulb in the HD Bullet headlight? I cannot find my instructions and before I go screwing it up I thought I would ask here first.
Old 06-08-2008, 06:31 PM
sokanxx's Avatar
sokanxx
sokanxx is offline
Default RE: Harley Bullet Headlight replacement
It's somewhat of a pain in a
&nbsp\\;
1/16-inch allen wrench, remove outer
set screw at bottom of headlamp shell.
&nbsp\\;
Remove the tiny chrome trim ring that is against the edges of the headlamp glass
&nbsp\\;
Then there is another trim ring that is to be turned counter clockwise to release and there should be an oring behind it
&nbsp\\;
Then pull out the sealed beam unit
&nbsp\\;
Now its just as simple as twisting the bulb out, replaceing it and putting it all back together the way you found it
Old 06-08-2008, 07:19 PM
greg3131's Avatar
greg3131
greg3131 is offline
&nbsp\\;
&nbsp\\;
&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&n bsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbs p\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\ \; When I purchased the 5 3/4 bullet headlight. They include a black bracket.....That is used for the removal process.....somehow
Old 06-08-2008, 07:36 PM
Airborne350G
ORIGINAL: sokanxx
[align=left]It's somewhat of a pain in a[/align][align=left]&nbsp\\;\\\\\\;[/align][align=left]1/16-inch allen wrench, remove outer[/align]set screw at bottom of headlamp shell.
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
&nbsp\\;
I took the outer (most forward) set screw&nbsp\\;completely out and the front trim ring still does not come off.
&nbsp\\;
Why did they have to make it suck a pain in the **** to change the bulb???
Old 06-08-2008, 07:58 PM
sokanxx's Avatar
sokanxx
sokanxx is offline
If youve got the tool it is for turning the second ring counter clockwise after you get the little chrome ring off. H-D literally suggests using packing tape to stick onto the outermost chrome ring to pull it out *LOL
Old 06-08-2008, 08:00 PM
Airborne350G
ORIGINAL: sokanxx
I got the three prong tool. So I gues mine is just being a pain. Time to go at it again. Thanks for the info.
Old 06-08-2008, 08:29 PM
Airborne350G
Ah, the outside chrome ring is screwed on also. I thought it was just a set screw holding it in. Once I got that it came off with just a few problems. That inner ring would get real tight and didn't seem to want to come out. LOL
Old 01-23-2021, 06:30 PM
Charles F's Avatar
Charles F
Charles F is offline
Dose anyone know where to get the three prong tool from??
Old 01-25-2021, 08:48 AM
greg3131's Avatar
greg3131
greg3131 is offline
The 3-prong tool is included with the bullet headlight . You can borrow mine if your located in southern Nevada .
Old 01-25-2021, 09:00 AM
Charles F's Avatar
Charles F
No I'm in Florida but I appreciate it! Looks like I'll have to make it..
leohd
07-29-2008 04:10 AM
ScooterJammer
06-23-2008 12:06 PM
jerryh57
06-06-2008 09:07 PM
Quick Reply: Harley Bullet Headlight replacement
