Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 03-28-2008, 10:29 AM
austiny austiny is offline
Prospect
Default RE: VANCE AND HINES BIG RADIUS?
Thank you all! All very good advice.
The bike is not at the Harley dealership sinceI live in the boonies, so I will get the pipes installed pretty cheap.
As to the other advice I think I will ride it after the new pipes are on and see how she rides, and then go from there.
Good to have all your advice if the thing don't work right!
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 03-28-2008, 11:39 AM
2007fxdc's Avatar
2007fxdc 2007fxdc is offline
Quote:
ORIGINAL: zombie
From everything I've heard, you don't need any type of fuel management with just the pipes andonly when you've replaced the AC along with the pipes
This is definitely true with most slipon mufflers. However, when you get into full pipes, it becomes less true. I ran my SE II's with nothing else for a long time with no issues or popping whatsoever. I changed them to V&H's straightshot slipons which are VERY open mufflers and started to get some popping even though they were only slipons. I had 2 directions to take. I could have probably added V&H quiet baffles and kept everything else as-is or I could add a fuelpak. When I called V&H's about the fuelpak, they told me that if I installed one, it would require a high-flow air cleaner as none of their thousands of dyno-tested/developed settings were done with a stock air cleaner. So, I jumped online and found a seller that had both a stage 1 a/c and a fuelpak for sale and they agreed to ship them both to me in one box. It took me about an hour total to install both myself (very easy although the FP is a tight fit). Popping was immediately gone and I had an instant improvement in throttle response and noticed a much nicer ride in the higher gears not to mention the engine runs noticeable cooler. When I changed out to Big Radius pipes, I opened the FP cover, reprogrammed to the new settings in a couple of minutes and I was done.
I've heard people complaining about the FP but my bike runs great with it. My only condition on buying it was that I definitely don't intend to ever go beyond stage 1 with my motor. Fuelpak, IMO, is fine for stage 1 but it really isn't designed for anything higher performance than that.
When you can significantly flow more air in and/or out of your motor, you need to adjust for more fuel. True, this is more critical for flowing more air in than out. But, when you get into full pipes or wide open slipons, you are starting to push the envelope with the outbound flow and that's why you get the popping, etc.
Just my 2 cents, but you spent $12k on the bike and $600 on the pipes. Spend a couple hundred more and do it right without taking any chances.
__________________
2007 FXDC, SE 180 rear, Chromed FXD wheels, Mustang Tripper Solo, V&H Big Radius, Stage 1 Complete, Kuryakyn Extended Forward Controls, HD Chrome Front End Kit, Progressive 412 HD, Jackyl 2" Tank Lift
Old 03-28-2008, 12:33 PM
golfblues's Avatar
golfblues golfblues is offline
2009 HD Heritage Classic
My Garage
[sm=exactly.gif]whatfxdc said.
__________________
Old 03-28-2008, 04:54 PM
ut_vols_fan ut_vols_fan is offline
What everyone else has already said +1
The exhaust and intake are generally a package deal: more air in....more air out. When you have more air in and out, more fuel is required to adjust the mixture richer. I went with the PC III, Big Sucker and Big Radius and love it. Also had it dyno'd when I was at Myrtle Beach Bike Week last year to get the fuel setting customized for my equipment. End result is I love the power and sound
__________________
http://i108.photobucket.com/albums/n..._fan/FXSTi.jpg
2006 Softail FXSTi - Fire Red Pearl
Vance & Hines Big Radius
Arlen Ness Big Sucker
PC III USB
DE Patriot Guard Rider #60446
Old 03-28-2008, 05:51 PM
Prospect
Just back from the garage and the new pipes are on and sound awesome!
The mechanic says the bike was set up with stage 1 and for screaming eagles even though the stock pipes were put on. The bike runs great in short tests without having anything done, no pop or backfire.
The mechanic suggests we wait and see after a longer test and the pipes get really hot!
Old 03-28-2008, 06:18 PM
golfblues's Avatar
My Garage
That was easy but with the stage 1 & new pipes you really should put a fuel mgt device on it. The Fuelpac is very simple even a caveman could do it & it's fairly inexpensive. The power commander isbetter but you will double the cost minimum for the unit & set up. Your choice but when that hot humid air comes around your going to wish you had one.
__________________
Old 03-10-2009, 07:22 PM
guzzishop's Avatar
guzzishop guzzishop is offline
Hang Around
Default V&H FuelPak
Quote:
Originally Posted by austiny View Post
O.K. so I bought this 2007 DYNA Super glide, very basic model, a couple of weeks ago and the first thing I wanted changed was the pipes.
I decided on Vance and Hines big radius and they were ordered and delivered to my local HD mechanic, and they are going on today.
So here is my question, along with these pipes $600 pipes, Vance and Hines recommends their $295 electronic gas regulator.
Do you have to have that?
What if you don’t install that?
Austiny,
I have a V&H FuelPak for sale on the Classifieds. I bought it new from West End Motorsports in January for $259. However, I was not able to make it fit under the seat of my 2009 Street Bob, so it has not even seen the ignition switch turned on. You can have it for $200. If you're interested, let me know and I'll ship it to you. E-mail me at steve.crawford@dom.com.
Steve
Old 03-10-2009, 07:32 PM
golfblues's Avatar
My Garage
Steve, the thread is a year old. Think you may have more luck with a PM to Austiny. Just saying.....
__________________
Old 03-10-2009, 08:10 PM
Maxcustody's Avatar
Maxcustody Maxcustody is offline
I had them on my Fatboy that was an 05. All I needed was the pipes and it ran great.
__________________
2009 Black Pearl Street Glide
Photo Gallery
http://hdforums.com/forum/members/ma...eet-glide.html
Old 03-10-2009, 09:32 PM
guzzishop's Avatar
Hang Around
Quote:
Good point! I'm new to the whole forum thing.
Thanks,
Steve
__________________
2009 Street Bob
Forward controls
V&H big radius with thunder monster baffles
SE Heavy breather
SERT
"In the practice of tolerance, one's enemy is the best teacher." Dalai Lama
Tags
09, 2007, big, dyna, fi2000, glide, harley, heritage, hines, installation, radius, settings, softail, street, superglide, vance
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
