To discribe my clunk. It sounds like a loose car front end control arm. I am sure that helped. not
On mine to reproduce the noise, roll the bike by hand a few ft fwd, nail the front brake hard this will compress the front end forks alot. and you can hear the clunk.
The front end will have to "reset" or relax and move back and reseat for it to clunk a second time.
From what I can figure the front end has a couple bearings that a "drop away" preload is set on. this is not where the noise comes from.
It is comming from below the upper tripple tree, and above the adjusting nut. it is the adjusting nut-washer to upper tripple tree clearance that has too much clearance, too big a gap.
My wonderfull dealer did the "first line fix" tighten the $hit out of the top nut.
this didn't fix it. I am told it often does.
The next step before the buletin came out in some shops was to grind down the washer for a tighter fit.
this did fix it I am told.
But the new fix replacing the washer is the real fix.
my dealer would not do it, they just said tightening was good enough. NOT
I am thinking of purchacing the washer kit my self and installing it myself.
Anyone know how to get a price on Harley part # 45727-07 ?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
Mick
2007 Dyna Wide Glide Black
tall HD back rest
battery tender
tmax w/auto tune
Fat Cats w/quiet baffles
D&M a/c
Will try to get a price today at the dealership......going to try to get ahold of one as i rebuild my Bob front end with the WG trees...perfect time to do it. I had the clunk before I took it apart. They tightened the snot out of the front end and gouged up the tree's in the process. This is the very reason why my bike was touched by service once and never again.
__________________
Mick
tall HD back rest
battery tender
tmax w/auto tune
D&M a/c
Just ordered part from dealer #45727-08? Only part number he had with description "steering stem washer" was only $1.70 (no -07 # as listed above). Will get copy of bulletin/procedure tomorrow and post details.
__________________
Mick
tall HD back rest
battery tender
tmax w/auto tune
D&M a/c
Thanks for posting this. Just a question to clarify....
Is this the washer that goes between the Fork Stem Nut and the upper fork bracket?
If the question is yes it should be easy to do myself. Just undo the Fork stem cap, take off the Fork stem nut, replace the washer, put the stem nut back on and torque to spec, then put on the fork stem cap and roll!
__________________
I just forgot my name
I see no sun today
And I've got nothing more left to say.
Gonna stop at the stealer this morning and inquire about getting this taken care. This is the first time someone has mentioned it being covered under warranty.
