Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
  #1341
Old 10-21-2009, 09:37 PM
Hickey's Avatar
Hickey Hickey is offline
Prospect
1988 Jeep YJ
My Garage
Default Alternate ignition switch
I used a two way toggle switch and some wiring. All it took was connecting the battery wire (red) and the ignition wire (red/black) to a toggle switch, run the lead of wires through the frame to where I mounted my toggle switch in the electrical caddy, and its good to go. Works like a charm, and now the keys can stay in my pocket However, the keys must be present for the alarm not to engage.
All in all, really simple!
here is a pic of how it mounts up, looks pretty sweet too. The small mods get me almost excited as the big mods do!
made a vid of its operation on youtube,
cheers
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
Hickey
  #1342
Old 10-21-2009, 09:50 PM
Citoriplus's Avatar
Citoriplus Citoriplus is offline
Moderator
Quote:
Originally Posted by Hickey View Post
This is a great mod, I did a variation of it. I closed the switch by soldering a wire between the two posts, then connected the battery leads to the power line going into the highbeam indicator light, and a ground source. So now when the high beam is hit, the garage door opens. Only works when bike is on, and doesnt run on batteries.
I hope the garage door opener is able to handle higher than normal voltage level. If I'm not mistaken that led is fed by the bikes running voltage of about 13.5V. While most garage door openers only use a 9V battery.
It might be best if you get a VOM meter and test that line to see how much voltage its really putting into the opener. If its over about 10V a resistor in the line will drop it to 9V for you.
I can't tell you how big a resistor it might need, but if you put a variable resistor (Pot) in between the LED and the opener you can adjust it to put out 9V to the opener and then measure it to find out what you need or just leave it in the circuit.
__________________
07 FXSTC
Thunder Max w/Autotune
V&H Big Radius, ScreamJet intake
U.S. Army Vietnam Vet
FOR THOSE WHO FOUGHT FOR IT - FREEDOM HAS A PRICE THE PROTECTED WILL NEVER KNOW.
  #1343
Old 10-21-2009, 09:56 PM
Hickey's Avatar
Prospect
1988 Jeep YJ
My Garage
The opener actually takes 12v, so it should be just fine. I've had it running for about 6000km, and havent had any issues.
__________________
Hickey
  #1344
Old 10-21-2009, 10:13 PM
Citoriplus's Avatar
Moderator
Good deal, but the info should still prove useful for anyone else wanting to do the same thing, like me.
Thanks for the idea. Now I just need to find another opener to do a little 'surgery' on.
__________________
07 FXSTC
  #1345
Old 10-21-2009, 10:18 PM
Hickey's Avatar
Prospect
1988 Jeep YJ
My Garage
Great point, sorry, got defensive, I was worried you were right lol.
__________________
Hickey
  #1346
Old 10-21-2009, 11:10 PM
Citoriplus's Avatar
Moderator
Not a problem, it probably would not be a real problem if you live in an urban or suburban area where you rarely use the high beams.
I just wanted to point out that if you ride a lot in areas where you actually use the high beams for an extended period like I do your setup will have the unit transmitting continuously and keeping it powered up like that with too much voltage will probably wreck it in time. Worse would be if it went up in flames and took something more important out with it instead of just popping a cap or resistor.
Your way would be a lot of fun though if all openers used the same signal, you would be opening and closing doors all over the place.
__________________
07 FXSTC
  #1347
Old 10-22-2009, 12:09 AM
WS6 Formula's Avatar
WS6 Formula WS6 Formula is offline
2006 Harley Davidson Low Rider
Same here, a little over three years and 20,000 miles with the 12 volt opener, no problems even when running high beams for extended periods of time. (Remote switch wired closed, battery terminals - one to ground, other to high beam wire)
__________________
http://hdforums.com/forum/image.php?type=sigpic&userid=9012&dateline=1218163  088
2006 Dyna Low Rider
Dragonfly Green Pearl & Vivid Black
Photos, Modifications & P/N's:
  #1348
Old 11-12-2009, 03:34 PM
mud's Avatar
mud mud is offline
Moderator
2006 HD SuperGlide
Over the last couple years several folks have asked about the mudBags.
Currently, Delmarksman is sending me a set of 40mm Grenade cans for me to prep for him.
I will modify to a sloped front, then he is going to execute the mounting apparatus....
Friend of mine sells junk, and I saw a pile of these cans in his *store* - Southern Treasure Hunters.
I asked about them and he said - why, you want one??
I said no. I want two. So he told me to take them
Set them on the floor of my shop and was stepping over them for about a week.
Finally, one day I was stepping over, looked down, and said - saddle bags............
This first picture below shows my cans in April of 2007 during the early development of the mudSickle........
I didn't snap a shot of the cardboard pattern, but that's the first step.
My cans are shown below in the early stage of the operation.
These cans are 14" long, 10 1/2" deep, and about 3 1/4 wide.
I like the compact size, they hang out just a cunnthair beyond the shocks.
Each can will hold about five beers and a sandwich, if you squash the sandwich down.
Picture below, I am checking alignment before I weld on the hangers.
Here below are the hangers, they slide between the struts and the fender.
Below is the position as installed.
.............continued in the next posting..................
__________________
  #1349
Old 11-12-2009, 03:35 PM
mud's Avatar
mud mud is offline
Moderator
2006 HD SuperGlide
.............continued from the previous posting..................
Here below in the first picture you see I welded on a tab to accomodate a locking device.
Also you see one of the hangers and quick release bolts that insure the cans stay where they belong.
Shown next is the flange nut I welded to the inside and the flange bolt that locks the cans in.
Here next, another view of both hangers and locking bolts as seen from above.
I've been running with the cans for going on three years now,
so, finally, the next two pix were snapped in July of 2009.................
Stay tuned, when I get the Grenade Cans, I will take some more pix.........
  #1350
Old 11-12-2009, 07:01 PM
Delmarksman's Avatar
Delmarksman Delmarksman is offline
Senior Rider
As always Mud, A great write up and great pics are worth 10K in words.
__________________
Fords and Chevy's kill more people than guns do.
Let's ban them.
Guns cause crime like cars cause drunk drivers.
'08 Dyna Super Glide
(Wrecked, was run off the road by a PU Truck)
Tags
1986, 2007, connectors, crimper, delphi, deutsch, diagram, front, fxdbi, fxr, fxrs, harley, reviews, signal, specs, tucking, turn, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
