Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 12-15-2007, 01:35 PM
dklozik's Avatar
dklozik dklozik is offline
Senior Rider
Send a message via AIM to dklozik
Default RE: Kuryakyn front signal relocate?
The bolts that come with the clamps dont fit the stock turn signals. You need a 5/16 x 24 thread bolt to work. Spacers are kind of a preference thing. Ive seen them with and without spacers. I personally used the spacers.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
21" Renegade front, Deuce rear, Big Radius, Big Sucker, ect.....
Dont look like no Bob !
Old 12-15-2007, 01:37 PM
Koppster's Avatar
Koppster Koppster is offline
Senior Rider
Thanks! Much appreciation!
Rick
__________________
2007 Super Glide Custom
Thundermax/AN Big Sucker Stage 1
Rinehart 2-2 Staggered
Old 12-15-2007, 01:42 PM
2007fxdc's Avatar
2007fxdc 2007fxdc is offline
Quote:
ORIGINAL: Koppster
So, you did NOT need spacers but you DID need two bolts?
The 49mm clamp kit comes with 2 clamps split into 2 pieces each and each clamp has 2 small bolts/screws that hold the clamps together. Probably a good idea to loctite those little screws and maybe even dab a little anti-sieze or even silicone between them as water can get in and rust it up over time. The kit also includes 2 bolts that go through one side of each clamp and screw into the holes on the signal lights. The bolts have a panhead on them so they will fit inside the clamp without sticking up and getting in the way. However, they will NOT fit into a HD bullet light. They are the right size but have the wrong thread. You will need to try and find a close match to those bolts with a fine thread. You'll want to test fit the bolts into the clamps to make sure that once they are installed they don't stick up enough to keep the clamps from fitting flush against the forks. Due to the curviture of the signal lights, they will not fit exactly flush up against the clamps so you can use something as simple as a small washer (I used a split lock washer that came out of my HD relocation brackets) to make them fit flush. However, others have used a pair of lock nuts. One you would tighten on the bolt against the clamp and the other you would tighten against the light once you have them adjusted how you want them. When I finish posting this reply, I'll see if I can find the thread that goes into detail about how this has been done by others and where they ordered their parts and specifically what they ordered and I'll come back and post that here.
__________________
2007 FXDC, SE 180 rear, Chromed FXD wheels, Mustang Tripper Solo, V&H Big Radius, Stage 1 Complete, Kuryakyn Extended Forward Controls, HD Chrome Front End Kit, Progressive 412 HD, Jackyl 2" Tank Lift
Old 12-15-2007, 01:59 PM
2007fxdc's Avatar
Here are 2 threads with more than enough information to get you what you need.
http://www.hdforums.com/m_2303438/tm.htm
http://www.hdforums.com/m_2411006/tm.htm
__________________
Old 12-15-2007, 04:03 PM
Koppster's Avatar
Senior Rider
Got, BIG thanks for taking the time to search all that out for me. Murphdog's links will be a help if the dealer(s) here don't have the bolts on the shelf. Looks like a very easy mod once you find the right bolts.
Now to learn how to put my bike pic in the post like you guys have!
__________________
Old 12-15-2007, 04:56 PM
2007fxdc's Avatar
Quote:
ORIGINAL: Koppster
There are threads in other forums to tell you how to creat signature pix and post pix in the threads themselves.
As for the bolts, you can check the dealer but just make sure you get one that maintains the clearance of the clamp. I didn't have trouble finding fine thread bolts that size but they all had heads on them that were too big.
Good luck.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
