Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Dyna Glide Models
Dyna Glide Models Super Glide, Super Glide Sport, Super Glide Custom, Low Rider, Street Bob, Fat Bob and Wide Glide.
Sponsored by: True-Track Inc.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 09-15-2007, 12:38 PM
up in minot's Avatar
up in minot up in minot is offline
Default Winter storage procedures . . .
I have a new '08 FXDC, and as of today it only has 550 miles on it. I'm located in northern (almost in canada) ND. Up here it's not abnormal for the temps to plummet to -70 degrees F or below (yes, that's a negative sign there) with the windchill. She's going to be stored in my garage, which is not heated.
Seeing as how I haven't reached HD's recommended mileage for the first service, should I still change out at least the oil and filter anyway? I understand that when they do that first service, it's mainly to be sure all the metal wear from the factory/break-in period gets filtered out. I'm mainly worried about having the fluids sitting in the bike, with the temps going from -70 or below back up to the +40's that condensation may form in the fluid housings which in turn brings water, which we all now that that water will freeze when it gets the chance, which expands asit turns to ice, which could crack the housings/make gaskets useless.
We do get a few nice days during the winter, but they maybe total a week in all. Not really worth starting her up, and taking her out.
Any suggestions???
Thanks,
-Olkie
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
__________________________________________________ ________________________________________
'08 FXDC w/ too much money in extras
The more you know, the more you know you don't know...
Old 09-15-2007, 01:22 PM
NightBob NightBob is offline
Hang Around
Default RE: Winter storage procedures . . .
Here's the procedure I'd probably follow:
1) Put wife in garage.
2)Put scoot in bedroom.
__________________
2007 Dyna Street Bob - Black Denim
All Bob. No Robert.
Old 09-15-2007, 02:01 PM
Good one!!! It took me 6 years to convince her to let me get a new bike, and now that I have it, she's getting a bit jealous. You should have seen her face last night when I called my bike "she"... ;-)
__________________
Old 09-15-2007, 02:10 PM
barefoot1313 barefoot1313 is offline
Prospect
Send a message via Yahoo to barefoot1313
move ta Texas
__________________
http://i191.photobucket.com/albums/z...ot1313/bf3.gif
she thanks mah harley's sexy
tis the measure of man, who can take what life deals out to him, and deal with it
07 superglide
Old 09-15-2007, 05:26 PM
TMace TMace is offline
Prospect
Yea Good old Mind Rot North Dakota. Left 2 years ago after spending 8 long years in that god forsaken place. At best you might be able to ride 5 months a years and 2 of those you will wear thermals.
Best thing to do is to add some Stabil to the fuel and run it for about 5 miles to make sure you get it throughout the fuel system. As far as the oil I would not worry about it but you need to change it come spring as over the winter with the temps fluxing a little up and down you will get a little condensation build up in the crankcase. Give it a good cleaning and wax job. Get a good cover and let it sit in the garage. Try not to bump into it with the snow blower either, don't ask me how I know that!
__________________
2006 WideGlide, Vance and Hines Big Radius Exhaust, Vance and Hines Power Pak, SE Air Cleaner
Old 09-15-2007, 05:50 PM
flynavy's Avatar
flynavy flynavy is offline
easy:
1) Fill your gas tank "almost" full.
2) Ride the bike straight home or to wherever you are going to store it.
3) Change motor oil, primary, and tranny fluids. *Note: Do not confuse this with "draining" the fluids. Better to replace them with new fluids for storage. Empty is not good.
4)Disconnect the spark plug wires, and remove the plugs. Spray fogging oil into each plug opening. Turn the bike over to circulate the fogger thru the cylinders a bit.Put the plugs back in and reconnect the wires.
5) HD or Kuryakyn or even Radio Shack make a cheap "smart charger." get one. Disconnect yor battery from the bike, and connect the smartcharger.
6) Spray a bit of wd-40 into the end of each muffler. This will displace moisture inside the exhaust and inhibit corrosion.
7) Cover the bike with a "breathable" cover. Don't use your outdoor cover as this will trap condensation under it.
That's it. The best part of all of this is it is so easy to do yourself, and in the spring, you connect your battery, take it out, and start 'er up. It may have a bit of odor after starting from the wd-40, but it will burn off quickly. Go for a long ride!!!
Been doing this procedure for years with every bike I have ever owned and it has never done me wrong.
__________________
2007 FXDB
V&H Straightshots Slip-Ons
Ness BS A/C~V&H Fuelpak
Nightrider XIED's
Old 09-15-2007, 05:52 PM
flynavy's Avatar
oh yeah.....forgot. Add to 1). Add fuel stabilizer to your almost full tank.
__________________
2007 FXDB
Nightrider XIED's
Old 09-15-2007, 05:55 PM
flynavy's Avatar
I live in New Hampshire. My bike and I are no stranger to long, cold winters.
__________________
2007 FXDB
Nightrider XIED's
Old 09-15-2007, 07:31 PM
Blade68's Avatar
Blade68 Blade68 is offline
2007 Harley Dyna
Quote:
ORIGINAL: flynavy
easy:
Brilliant!!
__________________
http://i49.photobucket.com/albums/f290/blade68/blade68siggy.jpg
2007 FXDL, Cycle Shack, Ness Big Sucker, PCIII
Old 09-15-2007, 08:09 PM
6165hd's Avatar
6165hd 6165hd is offline
[sm=boosign.gif][sm=WTFsgign.gif][sm=smiley26.gif][sm=smiley19.gif]Sorry guys I'm in denial of winter coming,,, I can't believe we are already discussing winter. Well, Thanks for sharing your storage methods. I will put them to use for sure. But Im hoping to get at least 2 more months in here in PA. Onlymother nature will make that call. We don't get minus 7 and below, just alot of soupy crap.
Cheers
[sm=icon_cheers.gif]
Joe
__________________
Cup of Joe
2008 Cross-Bones
SE Stage 1
SE Stage 2 103" Kit
SERT/V&H outlaw exhaust
Tags
blanket, breakin, davidson, fxdl, harley, motorcycle, procedure, procedures, storage, winter
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
