I'm thinking of replacing the rubber fuel tank crossover cable with the Braided Stainless Steel Fuel Crossover Line
It looks like it would be a quick and easy install but I'm making no assumptions. How hard is it to swap with the stockrubber crossover? Can it be installed without draining the fuel tank? Once installed, does it require any periodic tightening of the fittings?
This ad is not displayed to registered and logged-in members. Register your free account today and become a member on HD Forums!
__________________
Cheers!
TowJam
"I intend to live forever. So far, so good."
Steven Wright
I was going to do the same, but I heard concerns of it rubbing the bottom of the tank. Any comments?
I've looked at several installations closely in person and I don't see how they would rub the tank, There is plenty of clearance between the line and the tank - about the same as with the stock rubber line. Also, there is a clear plastic-type coating over the line - as far as I can tell, the only actual exposed "steel" pieces are the chrome fittings on each end.
__________________
Cheers!
TowJam
Steven Wright
This would only be a problem to those with a tank lift. No tank lift, no problem.
I'm thinking of switching to Braided lines because the crossover rubs the frame (with my 2" tank lift). The frame is making small slices into the rubber...doesn't give me warm fuzzies. So I'm gonna probably go with a longer length of Braided line to mitigate this.
Install was not difficult. Just the gas in the tank, and what to do with it. I've had mine on for over 5000 miles no problems rubbing, leaking, etc. However, I'm sure that somewhere I saw a quick-disconnect one(Russell I think), personally, I wish I would of got it instead. Just for making future work easier.
install is easy - drain the fuel if possible, otherwise .......
it will expose unpainted areas on the tank fittings .... mine are starting to rust
as mentiond by another member - forget about using this with the tank lift.
really not worth the money - but what can be bought at the stealer that is .......... oh ya - the service manual
when I take mine off this winter, I will replace with a quick disconnect type - don't care how much it costs.
I like Mudpuddles idea of bending the two crossover tubes down enough to keep the hose off the frame. I just haven't mustered up the cajones yet to do it. So far, all I've done is split another hose and put it under where it rubs.
