New Low Rider S
#1871
My Tape-Measure-Fu agrees.
At last conversation (last week) they are available from Bassani for the I and II. You are S.O.L. if you have an III, they don't (and won't) make it. I'm about to modify one from another model to fit, mine sounds great but it's too damn loud.
sempai (01-03-2017)
#1874
#1875
With swapping out for taller bars, at what point do you have to either extend signal wires or relocate the signals altogether? I have the 11" variation of the Lucky 13 bar from Lucky Dave's, as well as the brake/clutch cables from Magnum. Just not sure what I'm going to encounter with the signal situation. Any advice would be appreciated.
#1876
The following 2 users liked this post by BFMCdyna:
Hooligan317 (01-03-2017),
relykz (01-11-2017)
#1877
#1878
How did you get the clutch cable to work it seems now at 5.5 it's pretty much maxed? The brake line seems like I've got about 2 inches of play.
#1880
Yes, wiring is signal and control wiring. The clutch cable and brake line is maxed out at an 8" rise after moving the clutch cable out from under the motor. You might pull an inch or two more from the clutch with adjustment, but it will be tight.
