New Low Rider S
#1521
Those numbers don't seem realistic for an otherwise stock 110 with only a TH.
#1522
[QUOTE=jcanrun;15525896]
Decided to install an old style cafe racer fairing today. I didn't want to change anything else as I like the bars and such. Anyway here is the result:
LOOKS GOOD. Ok, here are the expected questions. What brand fairing is that? How did you mount it? Where did you buy it?
#1524
Originally Posted by Mchad
What bike is that on? A Low Rider-S? Printout says '16 FXDB-I and 103ci...
#1526
@Mchad, it is my FXDLS....I meant to get pics today, but ran out of daylight. I read the fine print on the dyno after I got home, and saw the 103ci and was like WTF, but then thought that's just a note, and I could trust the numbers. If you think differently, I'll definitely be stopping back to recalculate.
#1527
#1528
#1529
New photos
My FXDLS:
Thunderheader (defintely loud AF)
MasterTune2/dyno tune (runs cooler/smoother, increased mpg)
Roland Sands Boss seat (passenger seat not comfortable, but I like the stitching)
HD detachable sissy bar
LeatherPro detachable saddlebags (expensive but worth it)
GBG rear turn signal relocation (better night visibility)
HD passenger pegs
Future: 12" apes
HD passenger pegs
Future: 12" apes
huggies (10-09-2016)
#1530
Installed my Ultra Cool oil cooler
I installed my ultra cool oil cooler this weekend. This bike needed a cooler bad, I don't know why one didn't come on the bike. The bikes in the press release pictures for the magazine intro had coolers on them.
I looked at all the oil coolers. And had a hard time deciding which one to get. HD or aftermarket. Side mount on the down tube or low mount. This bike really gets hot fast in traffic and waiting on lights. So a fan assisted cooler seemed to be the way to go. I've had water cooled bikes that the fan would blow hot air on your leg so I wasn't crazy about a side mount in front of my leg.
The install went fairly easy except routing the left hose. I looked at the pictures on the ultra cool website and tried several routes until I was satisfied.
I will give a tip to support the motor with a jack when installing the heat exchanger mounting bracket. That will prevent stripping or cross threading the top bolt when putting it back in. If you don't support the motor when you loosen the bottom bolt after removing the top bolt the motor will drop down and the top mount hole will open up and be out of alignment with the hole in the frame. Support the motor on any brand of cooler that mounts this way.
I ran the wire along the right side frame rail to the area under the seat and used Harley's electrical connection harness part#72673-11 to tie in switched power.
I rode it about 5 miles so far and no leaks and the fan runs like it's supposed to. I'll put a few miles on and change the oil.
