Show off your bars and risers!
Old 12-08-2015, 10:44 PM
CWS's Avatar
CWS
CWS is offline
Originally Posted by monster715
I got short arms (5'10"ish) and I wanted to sit a little straighter and not so stretched. Plus I like the look of the tach/ speedo stood straight up. Maybe someday I'll try it out. I like this setup way better then the 10" tbars I had before
I think I might be convinced on the pullback risers then considering I'm 5' 9". I'll probably go with like 10" pull back risers with a 2" pull back. Seen a lotta guys rocking that.
Old 12-09-2015, 09:30 AM
bringtheruckus's Avatar
bringtheruckus
bringtheruckus is offline
Bought the bars and risers off a forum, not sure what they are, but i believe the risers are cycle standard 8" and I just swapped to a sportster bar to get a little bit higher. Considering some pullback risers too since I hunch so much.
Old 12-10-2015, 07:29 AM
Jeff's 1st Harley's Avatar
Jeff's 1st Harley
Jeff's 1st Harley is offline
Here's mine I love em.
Attached Thumbnails Show off your bars and risers!-117.jpg   Show off your bars and risers!-002.jpg
Old 12-10-2015, 07:54 AM
Vonswanko's Avatar
Vonswanko
Vonswanko is offline
Guess I should've added pics
Old 12-10-2015, 02:21 PM
Shizims's Avatar
Shizims
Shizims is offline
Originally Posted by Nikolaiownz
I love this setup. I am making some 10 inch risers and getting sportster handlebars aswell.
What grips are thoes? 7/8? I am looking to get some mx style grips på mine aswell.
Look up Baxter X grips, MX style fits 1" controls
Old 12-11-2015, 12:05 PM
Grefven's Avatar
Grefven
Grefven is offline
6th Gear
10" murdockrisers with trackerbars.
And yes, I should have hidden the wiring better. Guess thats on my to do list over the winter.
But you get the idea...
Old 12-11-2015, 05:39 PM
Cafard's Avatar
Cafard
Cafard is offline
I got 11" FM risers brand new anodized black for 1"1/8 Pro taper. Drilled for wire and they come with the 7/8" -> 1" sleeves. I can throw grade 8 bolts and im asking 220 usd + shipping. Pm me if you want.
Old 12-12-2015, 07:27 AM
Maxxsmart's Avatar
Maxxsmart
Maxxsmart is offline
Making shirts back there?
All that water, you must have had a fun ride!
Old 12-12-2015, 08:15 AM
Vonswanko's Avatar
Vonswanko
Good eye! It's a left over screen from a few years ago.
Rain or shine, the Dyna gets ridden. There's no bad day to ride, just bad gear.
Old 12-21-2015, 09:09 AM
Fxdustin's Avatar
Fxdustin
Fxdustin is offline
Stage II
8" dynamic Dyna risers with pro taper mini lows. Just over 10" tall. The risers are very well made and look killer. i milled new holes in the bars to line up with the middle of each riser and ran the wiring through to the bottom of them. It was a tight fit but it looks really clean.
Quick Reply: Show off your bars and risers!
