2012 Wide Glide riser extension
Old 12-08-2015, 03:29 PM
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,751 Likes on 3,962 Posts
Originally Posted by SPCJ
With the riser extensions what is the total height of the risers? I've seen two heights for the stock risers. 4.5in and 5in. I'm looking at getting new risers but want to make sure I don't go too tall. Thanks!
The stock risers are 4.5" from the base of the riser to the bottom of the saddle cutout for the bars...
Old 12-09-2015, 07:55 AM
SPCJ's Avatar
SPCJ
SPCJ is offline
Perfect. Thanks!
Old 03-06-2016, 07:09 PM
Hondahawkrider's Avatar
Hondahawkrider
Hondahawkrider is offline
Great post thanks
I was replacing my bars with later OEM ones and needed just a little extra... Instead of new risers. These will work
Old 03-16-2016, 01:46 PM
Hondahawkrider
One issue
The 3in riser bolt was long enough on my 03 dyna that you'd have to loosen up a lot of the front forks
Old 03-16-2016, 01:47 PM
Hondahawkrider
Good news is the 2in risers fit easily and was the right height
Old 04-26-2016, 12:36 AM
up4daz's Avatar
up4daz
up4daz is offline
Stage III
Default Hey guys new member but been looking at these forums for years
On my '13 Wide Glide I'm running the DK Custom 'fat' riser extensions, they're 2" tall and 1.5" in diameter. With 2" tall extensions you won't have any issues with cables or lines save for re-positioning the brake line in the two retaining clamps and the extensions look great. I also replaced the rubber bushings in the upper clamp with solid chrome bushings, the riser is now solidly mounted to the clamp, no movement of the bars/riser.
The riser extensions are an inexpensive way to bring the bars up and back and improve your riding position, $35 well spent
http://www.dkcustomproducts.com/2-In...2-SFT-RSRS.htm
http://www.demonscycle.com/chrome-ha...dson-4120.html
Hey tincup I got to ask if you don't mind I also have a 2013 Wide Glide I just picked up these DK risers after reading your post I am curious did your risers extensions arrive scratched and chipped? Now I don't expect them to be perfect but I would at least hope that there would not be bare metal where rust can start to accumulate they came wrapped in the foam but I gotta tell you they look like they've been thrown around on the shop floor.
Old 04-26-2016, 05:57 AM
Mchad's Avatar
Mchad
Mchad is offline
Received 3,538 Likes on 2,145 Posts
I bought 3" riser extension from DK and they arrived in perfect condition. Give them a call, they will happily exchange them I'm sure.
Old 04-26-2016, 07:44 AM
scott504's Avatar
scott504
scott504 is offline
Up4daz, I ordered a set of the 2 inch from them back in January and they arrived chipped and scratched. I had to return them, the replacement set that they sent were better but not perfect. I didn't bother to return this set, I used a black sharpie for touch up.
Old 04-26-2016, 08:36 AM
up4daz's Avatar
up4daz
up4daz is offline
Stage III
Thanks guys just figured I'd ask, if these were tiny chips and scratches I wouldn't worry but these are a little smaller than a BB.
Old 10-16-2016, 11:48 AM
smalls78's Avatar
smalls78
smalls78 is offline
Old thread I know, but when installing the DK riser extensions, should I use RED Loctite or just BLUE?
Can the RED Loctite be "undone" in case I ever want to remove them again?
Quick Reply: 2012 Wide Glide riser extension
