Need some tail-light/turn-signal setup inspiration for FXDB
I picked up a base model 15' Street Bob right before Xmas. I'm not digging the side-mounted license plate and stock location and style of tail/turn lights.
Even after pouring over pics of various setups, still could use more ideas and inspiration.
Could folks here be kind enough to post up pics of your modified/aftermarket tail-light and turn-signal setups using the stock "bobbed" fender.
Some day, I may spring for a Super Glide fender swap, but for now, I gonna keep it as is.
Thanks.
Thanks.
Here's my current setup. In the next few months I'm going to be changing over to a fender like yours. I'm planning on putting the license plate/signal combo pictured here onto the new fender, and rewiring it so the two lights work as the brake light as well, like the newer Street Bobs. I may cut the stalks shorter also.
I had this set-up. Got the idea off the gentleman here with the green street bob. It's a Harley softail relocation kit / stems- that was used on the rear fender piece that is standard here in Australia, but is available as a license plate relocation solution for you in the US.
But i've also just installed the Great Bike Gear kit yesterday. I'm much happier with it. Just waiting on the illuminator to install.
