Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Classic
Classic All 'historic' bikes.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 09-17-2009, 04:51 PM
paullavery paullavery is offline
Hang Around
Default WLA Advice
Can anyone give me advice on updating my 42WLA, after getting the motor and transmission out today I have found out that the motor is not original as I was led to believe when I purchased the bike, so have decided rather than restore it to its military spec i will civilianise it & enjoy riding it ! So will remove the military bits and change the overall look of the bike, I would like to change the carb and the old oil bath air filter - any suggestions as to what I should use ? Also is it possible to change the transmission from 3 to 4 speed ?
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 09-18-2009, 01:47 AM
FilthyLucre's Avatar
FilthyLucre FilthyLucre is online now
Senior Rider
When you say not original what do you mean? They made 42 WLA's for several years during the war and always kept the 42 in the serial number, the belly numbers may indicate manufacture in 43 to 45. You are pretty much stuck with a 3 speed unless you want to add a reverse gear transmission, which unless you had a sidecar would be pointless. With the plumber style manifold you may be better off keeping the linkert. You can still get civilian style air cleaners that are period correct to fit it.
__________________
57 FLH
68 FLH
72 FLH killed 12/15/08 by an SUV
75 FXE
69 LE
Lű cre (kər) n. {OFr. Lucre, from L. Lucrum, gain. Riches; money: now chiefly used in a humorously derogatory sense; as in Filthy Lucre
Old 09-19-2009, 12:44 AM
Hang Around
Turns out the engine number is not original, although it is stamped 42wlaxxxxx it is not the original typesett used by HD, (my mistake really, should have done more research before buying) !
After stripping the bike down and removing the motor, i was hoping that the belly numbers would match, but alas 'no such luck' !!
I don't really think the guy I bought it from was any the wiser, as he owned it for 6 years, but i'm sure the guy that supposedly originally restored it in 2003 new exactly what it was !!!
Oh well, always look on the positive side, had a great time stripping it down, (took me back to my teenage days, when me & my mates would spend hours pulling bikes etc apart and putting them back together, usually to find they were worse after the event lol, but a good learning curve....) I only hope i can get everything back together again, as it was such a blast to ride !!!
Will pobably leave off the military extras and change a few bits, thanks for your recommendation on the air cleaner, will look for a civvy version.
Old 09-19-2009, 02:46 PM
Senior Rider
Another thing on WLA numbers is that Harley sold the army many blank motor cases as replacements. Could it be a case where a motorpool replaced a damaged motor case and transfered the numbers?
__________________
57 FLH
68 FLH
75 FXE
69 LE
Old 09-21-2009, 01:22 AM
Hang Around
Well she is finally completey stripped, now it is off to the powder coaters for the frame, wheels, forks and a few extra bits and pieces !
I am going to replace the 8 springs making up the springer forks but not sure if I can just undo the nuts at the top and remove these, or do i need a special tool for doing this ?
Also is it easy to remove the throttle and advance cables from inside the handle bars, I had a quick look by removing L/H side grip and retaining screw at the end and taking off the swivel control, but looked to me if it would not be so straightforward to re-assemble ?
Cheers.
Old 09-22-2009, 01:23 AM
Senior Rider
My best advice is to get the manual and parts book. You don't necessarily need a 1942 manual. The 45 motor was used almost unchanged from 1940 to 1973. The two wheel version was made up to 1952 I believe and the servi-car to 73.
__________________
57 FLH
68 FLH
75 FXE
69 LE
Old 09-22-2009, 03:07 AM
Speeding Big Twin Speeding Big Twin is offline
Hang Around
Paul, sorry to hear things are not going smoothly. But I have to ask why you think the serial number was not applied with the proper factory stamps for that year and model. What are you using for comparison? Can you post a photo of part of the serial number?
A couple of other things you could record for future reference are the casting number and casting date code on the left crankcase. And you may find a casting number and casting date code on the underside of the transmission case oil filler spout.
Re the handlebar controls, I had the original setup on at least one of my WLAs and I don't recall any problem with assembly. I also had an original internal throttle on both my Shovel and Pan and again, no assembly problems. Eric
Old 09-22-2009, 11:51 AM
mjmangus mjmangus is offline
Senior Rider
J&P Cycles has a pretty decent Vintage Bike Catalog. www.nosparts.com is another great source for partsfor both military and civilianized versions of the 42WLA. You can also search the internet for images of the bike and that will give you some ideas on what you can do.
__________________
2007 Softail Custom
2005 Road King Classic
1991 CHP FXRP
1942 WLA (Civilianized)
Old 09-22-2009, 02:29 PM
Hang Around
Have managed to get the springs off the forks, I used a ratchet strap & it worked a treat !!
Have decided to go for a new set of handlebars that have all the cables pre-fitted from 45 restoration parts & will probably get a civilian air cleaner at the same time.
Eric, with ref to the engine number, i posted a picture of it on the 42wla group site on yahoo for advice & it was clear from the response I got that it was not original when you compare with others & also after taking the motor out the belly numbers are not matching, so anyway I am quite happy with my decision to civilianise the bike and add my own touch to it as I am looking at keeping it long term.
Frame, forks and various other bits are off for powder coating on Thursday so will keep you posted, i will post pics some pics if i can work out how to do it !!!
Thanks for all your helpful comments & input.
Paul.
Old 09-28-2009, 12:03 PM
Senior Rider
Here's a pic of my WLA. It looks a little cluttered with the Road King in the back but you get the idea.
__________________
2007 Softail Custom
1991 CHP FXRP
Tags
42, 42wla, 45, air, bath, davidson, day, filter, frame, harley, location, made, oil, parts, project, war, wla
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
