Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > Harley Davidson Motorcycles > Classic
Classic All 'historic' bikes.
Welcome to HDForums.com!
Welcome to HDForums.com.
Thread Tools Search this Thread
Old 10-11-2005, 04:25 PM
imboden's Avatar
imboden imboden is offline
Default 1942 Knucklhead...Float Stuck?
I'm trying to get this thing running again, so I cleaned up the mag and plugs...filled my tank up, kicked and kicked....got nothin but good compression. so I give up for the day, put her back in the garage, and next day while I'm at work wife calls and says all the gas leaked outta the tank.
what's my next step here? dad told me he thought I probably have a stuck float, but I'm not sure how to check that on my float bowl. anybody have tips?
thanks-
pat
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
Old 10-11-2005, 05:56 PM
Terry1955's Avatar
Terry1955 Terry1955 is offline
"Administrator & Troll Slayer"
2000 Harley Davidson Screamin Eagle Roadglide
Send a message via AIM to Terry1955
Default RE: 1942 Knucklhead...Float Stuck?
You probably have a bunch of old gas in the float bowl. Remove the bowl and clean out any dirt or old gas and inspect you float. You may have to replace it because sometimes they will leak and soak up gas which will cause them not to float anymore. The float should move up and down freely.
Terry
__________________
Old 10-11-2005, 07:20 PM
imboden's Avatar
thanks terry, will get back if I have any problems.!!
Old 10-13-2005, 12:09 PM
Crazyace Crazyace is offline
Hang Around
Also you can take the bowl off hold it upside down and blow through the fuel inlet to see if your needle is seating properly - if you can't blow through it while its upside down then needle seats and stops the flow of fuel when the float gets to its highest point. Turn it right side up and you should be able to blow through it with no problems. When your trying to start the bike did you make sure your getting fire to the plugs? Are you getting gas down the throat of the carb? Anyway hope this helps.
Old 10-13-2005, 02:51 PM
imboden's Avatar
I do have fire in the plugs, checked that! as far as the bowl, I'll be working on that tonight to see what I can do.... yesterday was a project on a 72 superglide....I'll post on that in a minute.
Old 10-26-2005, 01:29 PM
cbrunson cbrunson is offline
Senior Rider
If it has been sitting for a long time, I would pull the carb off, and take it apart. Some may not agree here, but I would soak the parts in gas over night. I use to fill an old coffee can or something with just enough gas to cover the parts. The gas will soften varnished gas and debris. Then after soaking it, I would spray the parts off with carb cleaner, and reassemble. I’m not familiar with that carb specifically, but the floats can usually be adjusted by the amount of tension on the spring the seats the float jet. Most of the time you just need to adjust the float and clean the seat/jet.
Old 02-19-2006, 03:59 AM
Mordwyn Mordwyn is offline
Send a message via Yahoo to Mordwyn
Plastic floats absorb gas when they get old and metal one's rust out, making both worthless as fuel controll devices. Take off the carb and then +1 to What CBrunson said... This will give you a chance to closely inspect all the jets and your primariy ports emulsion tube for wear and or corrosion. Who knows, maybe a rejet will give you a few more MPG or HP
Just make sure that if you strip the carb that you do it in a well lit area far away from nooks and crannies. If luck is anything like mine, thats were all the small parts go as they flee in terror from me, never to be seen again.
I usualy strip carbs in a medium sized rubbermaid tub, everything then stays exactly where I can see them with no chance to escape... a minature parts POW camp so to speak
__________________
TANSTAAFL!!!
Wahabi Delenda Est
Old 05-14-2006, 05:58 PM
imboden's Avatar
thanks for the tips, I got her all figured out, sold it on ebay for like 10 grand. but I've got a few more to go through, next one will be a 37 knucklehead
Tags
37, bike, bowl, carburater, carburetor, dirt, fix, float, frame, gas, harley, harleydavidson, knucklehead, knucklhead, point, soaking, stuck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
